Need Advice Fixing Broken Flow Meters in Hydronic System
We're updating an old system that has about 10 hydronic manifolds. A lot of the flow meters aren't working anymore. Can we just replace the broken meters, or is it better to get a whole new manifold? If we can just replace the meters, what's the best brand to go for?
Thanks for your help.
    hot_rod Member Posts: 27,812
    Those look incredibly clean, most time they are too dirty to even see the indicator.
    Are you sure they aren't turned off. Really not much to go wrong, a spring and a plunger is all it is.
  • seeking_quality
    seeking_quality Member Posts: 12
    Bob, that's good news. Incredibly clean is a rare comment. Thank you!
    EdTheHeaterMan Member Posts: 12,497
    My guess is that you can carefully remove them, then inspect the innerds (innerds is a technical term) and just clean them up on the inside if there is any gunk on them.
    EBEBRATT-Ed Member Posts: 20,467
    Maybe they are ok. It says GOOD on the wall LOL.
  • seeking_quality
    "Maybe they are ok. It says GOOD on the wall LOL. " ok, that was a good one!
  • seeking_quality
    Ed: "inspect the innerds", we will try, thank you!
    You kinda need to break them to get inside. Probably easier to buy replacements, if in fact they are damaged?
  • seeking_quality
    Ok, sounds good. Thank you!
