Distance between fittings and circulator
Is there a minimum distance between say a 90 and a circulator, on a oil fired boiler?
    hot_rod Member Posts: 27,846
    Best practice is 12D, 12 pipe diameters up or down stream. So 12" for 1" pipe or tube.
    No flow restricting devices up stream of a circulator. Air separators are fine upstream.
    But even pump manufacturers break this practice by putting check valves in the discharge of the volute. Go figure.
    PC7060
  • If space is a concern, I’d pay more attention to the suction side of the pump, i.e. 10 diameters of straight pipe.
    edited October 2023
    12D, 12 pipe diameters, so for 1” pipe or tube 12” is best practice on both sides of a circ
    no check valve or flow restrictive devices at the suction
    But even the pump manufacturer break this rule with IFC checks  in the pumps
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,363
    @Orangecoleahh I've merged your duplicate posts into one here to prevent confusion. Thanks.
    President
    HeatingHelp.com
  • neilc
    neilc Member Posts: 3,196
    Hi @Erin Holohan Haskell
    there may be a glitch in the interwebs,
    This is a second "merge" where I only see about 5 messages of this thread,(happened on another where I tagged you on the duplicate threads),
    Where is all the starting messages to this thread?
    known to beat dead horses
    @neilc, I usually merge the posts and then remove anything that is duplicate, like the OP's initial question repeating. I'll keep an eye out for glitches. Thanks!
    President
    HeatingHelp.com
  • neilc
    ty, for all you do,
  • RobertHoward
    RobertHoward Member Posts: 1
    For optimal performance and to reduce strain on the circulator, maintain at least 12 inches of straight pipe between fittings like a 90-degree elbow and the circulator on an oil-fired boiler system. This helps ensure smooth flow and efficient operation
    PeteA
