Low water cut off
HAPLUMBER
HAPLUMBER Member Posts: 14
I have a low water cut off model # PS-801- RX2- 24. Its a 24 volt low water cut off. I hooked up a unimatch feeder to it and the feeder is not kicking in on low water. I can fill it manually
    EdTheHeaterMan Member Posts: 12,504
    edited October 2023
    Are you sure you have a PS-801- RX2- 24. I can not find that part number anywhere. Maybe it is a PS-802- RX2- 24?
    If it is a PS-802- RX2- 24 then this wiring diagram is what you need to follow.
  • HAPLUMBER
  • HAPLUMBER
    I had the same problem. I can't find the part too. It a remote probe. The probe is in the front of the boiler and the control is in the side
