Monoflow tees
GFORCE
GFORCE Member Posts: 1
I'm sure this has been discussed about a million times but I'm wondering if you can help clarify flow direction through this monoflo t?
  • Hydromatt
    Hydromatt Member Posts: 3
    edited October 2023
    Grooved line always goes between risers. If one tee per emitter is used it goes on return.
    EBEBRATT-Ed Member Posts: 20,485
    If you install the tee so the branch pipe is the supply to the radiation you use the top arrow in your picture to determine the flow direction in the main.
    If you install the tee so the branch pipe is the return from the radiation then use the bottom arrow to determine the flow in the main.
