HOW TO CONNECT FAN IN CAN TO BURNHAM SERIES 2 206-EN
FeelingColdColdCold
Member Posts: 15
Need to add fan in can (make-up air system Field Controls CAS-4) to the boiler installed. The only way electrician believes to pull the 24V off the boiler is by splicing into the gas valve. Electrician doesn't want to splice here. Does someone have solution on how to wire off this boiler?
- 128 Chimneys & Flues
