need help identifying this Honeywell valve - leaking stem
bkc
bkc Member Posts: 41
Hi,
We have this older 3/4" honeywell valve that is leaking from the stem.
I'm having trouble determining the model number because it has a threaded male/union end.
The valve just started leaking this season. I don't think the stem is scored/grooved. Its on a rarely used line and leaked about 2.5 gallons in one week. I have turned off the supply to that line.
Is this possibly compatible with V5011F rebuild or repack kits? Can I get away with a repack?
Thanks for any suggestions,
-Brad
    EBEBRATT-Ed Member Posts: 20,485
    This looks similar different actuator
  • Big Ed_4
    Big Ed_4 Member Posts: 3,551
    It seems that it needs to be repacked ....
  • retiredguy
    retiredguy Member Posts: 1,100
    edited October 2023
    Look closely at the flats on the top of the valve where you are supposed to use a flat jaw wrench to turn the head. (not a pipe wrench that chews up the brass). See those numbers, which you can see in the first and second picture on the flat below the right hand bolt, of the actuator. Record those numbers and call your local Honeywell rep. They should be able to supply you with a rebuild kit.
  • dko
    dko Member Posts: 669
    edited October 2023
    My best guess is that it's a V5045A1130 with (if original) ML684A actuator.
    But you can confirm once you can see the imprinted model on the brass.
    You can just buy the entire valve on ebay for quite cheap. V5045A has been replaced by V5011N (parts not compatible).
  • bkc
    Thank you everyone for your suggestions, it does indeed look like a V5045A valve.
    I found a 'new in box' one on ebay for $28 .. a great deal if it shows up and is actually new.
