Buderus 5720724 Room Sensor - all LED lights flashing in sequence
colemanoid
Member Posts: 1
We just purchased a home with Buderus boiler for the radiant floor heating system. There is a Buderus 5720724 room sensor on the main room. All four LED lights (including the vacation light next to the image of an umbrella) are flashing in a chasing sequence. When I push one of the buttons (day setting, auto, night setting), nothing happens. Can someone tell me what this flashing sequence means? I assume either the sensor is not working properly or that there is something else wrong. I have looked in the operating manual and do not find anything about error codes or light sequences.
One Pipe System0 -
You will need to go in the Logamatic control and switch on room sensor . Down load the manual or call tech support 1(603) 562-1100 . Busness hours eastern
I have the same issue. Intermittent blinking BFU but not a new system (installed in 2005). Seems to function correctly when not blinking. Changing polarity of wires does not improve it. Replaced BFU, no change either.Any ideas?0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
