Which Boiler do I need ?
I have a large system in concrete and under subfloor. Needing boiler and mechanical panel. I also need to generate DHW. Looking at the NTI boilers to supply my system.
199,000 BTU, 5 zones, propane. The FTVN and TRX look to be my choices but not sure which one. also is it best to have a DHW storage tank or boiler heat exchanger.
    hot_rod Member Posts: 27,812
    How big is the slab, select the correct size boiler based on the load you are connecting to
    DHW from either an indirect tank or a combi boiler.
    It depends a bit on your hot water usage. Combis give you endless hot water at low flow rates, 2-4 gpm
    A tank could supply any gpm, until it runs cool.
    So either a tank sized for the dump load. Or work within the combis output.
    Mad Dog_2
