Hydronic floor in slab under fire stove
MichaelQC
MichaelQC Member Posts: 1
edited October 2023 in Radiant Heating
Hello everyone,
I am installing a hydronic floor in my slab, I will have a smallish fire stove I will use occasionally that will be standing on 12 inch legs. It's a cast iron high efficiency 46000btu smallish stove.
Probably will install a granite/mortar hearth for the fire stove area 4" high, if not I will definitely install some sort of  flooring to protect concrete from cracking (porcelain tile with something underneath). Do you see any issue with me installing the PEX A pipe in the slab under the fire stove?
I think it should be fine, but I am afraid the heat of the stove will radiate and bring the slab and the PEX pipes temp above its spec.
I guess having the granite base is not an issue in itself ( will just limit and slow the radiant heat from the hydronic)
  • Intplm.
    Intplm. Member Posts: 3,081
    As a precaution, I would avoid the radiant close to that much of a heat source.....the wood stove.
    Similarly, when installing radiant in a floor near a wax ring on a toilet I usually keep the radiant floor heat away from the wax ring too.
    hot_rod Member Posts: 27,812
    A simple heat shield made from a piece of aluminum or stainless sheet metal will make a big difference below the heater.
    That is how double and triple wall flue pipe is built. A small air space to keep the outer pipe from over heating. Some stove manufacturers offer “heat shields” for under or behind wood stoves.
  • Dave Carpentier
    Dave Carpentier Member Posts: 640
    I agree some kind of shield in/on a raised platform would ensure.
    Maybe worth burying a couple of thermal sensors near the pex ? That way you could monitor for a year or so just for peace of mind.
