Insulating an Unfinished Basement?
PilotPat24
PilotPat24 Member Posts: 106
Hello,
I have a house on Long Island, NY with an unfinished block wall basement foundation. Currently I have the rim joist insulated with spray foam and 3" of closed cell foam. The floor joist of the first floor are insulated with R-30 Fiberglass Bat.
Would there be any benefit to insulate the walls of the basement? Thanks in advance.
Pat
    hot_rod Member Posts: 27,859
    Certainly there is heat loss through the basement walls. This program allows you to build the wall, and determine the heatloss. www.hydronicpros.com
    I'd spray foam those also.
