To flush or not on closed loop boiler system
Swilson08
Member Posts: 36
in Oil Heating
I have a well McLain wtgo that's probably 15-17 years old. I know the original theory was you should never flush a hot water closed loop system as it would put oxygen into the system and cause rust. Is this still the case? Or do these need flushing these days? If I was opening the system to replace a pump or do pipe work then I'd probably just flush it since it was open. But should we be actively flushing these systems every few years or anything ?
No. Unless you have issues with heavy bacterial growth, Water 💧 in these closed systems will usually settle in to a nice balance. Mad Dog0
