oil boiler replacement
Our Burnham oil boiler is 26 years old. It has worked great but we would like to replace it before it develops a major leak. What Burnham boiler is a good replacement for model RSH-113? How can we find out? We hear all kinds of conflicting things from the local companies. Thank you so much!
  • SuperTech
    SuperTech Posts: 2,723
    edited October 2023
    Any particular reason why you want another Burnham? Proper sizing and installation is a lot more important than brand name. First thing you should do is a heat loss calculation to determine what size boiler you actually nred, most boilers are terribly oversized.
    Personally I would consider a boiler from Energy Kinetics. My second choice would be a three pass boiler such as Pure Pro Trio, Utica Tri Fire or Burnham MPO.
    szwedjSTEVEusaPAIntplm.
