New Gas valve receiving 24v wont open 2
170 Member Posts: 1
I'm having the same problem. I have the volts but not the amps. Had a bad valve last April and replaced the board as well as I did not want to buy a new furnace. I saved the old board and will put it back in. I do not like the new board as it was programmed by lawyers to blow the furnace clean before ignition-too much suspense.
    EBEBRATT-Ed Member Posts: 20,397
    I have no idea what you are talking about
    HomerJSmith
  • Solid_Fuel_Man
    Ummm, hmmm. Lawyers and control boards....24 volts but no amps? Hmmmm
  • HomerJSmith
    HomerJSmith Member Posts: 2,793
    edited October 2023
    It is probably wired up wrong, check the wiring. How do you know there is 24 Vac at the gas valve?
    Pre-purge of the combustion chamber is good. Pre-purge has more to do with the control board than the gas valve.
    Is this a boiler or a furnace? Some people don't know the difference.
    There is a whole line of safety switches before the gas valve any of which will shut down the gas valve if they don't close.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,545
    Never post during happy hour ....
  • HomerJSmith
    O.K. guys give the guy a break. Were here to help. You know Heating Help.com.
    EdTheHeaterMan Member Posts: 12,453
    I looked at his previous post where he asked about this problem last year. I sort of remember this one...
    But there was no previous Discussion?!?
    I would like to add what I would say to my apprentice technicians every time they condemned an expensive part (or something that needed an expensive repair):
    “After you replace that part and it does the same thing, what will you check next?”
    Sometimes the answer was as simple as “The Fuse”
    I would tell them to check the fuse first.
    So @170 Describe your conditions:
    What brand and model number heater do you have? With that we can look up the sequence of operation and see where the failure is happening.
  • realliveplumber
    realliveplumber Member Posts: 354
    Was the thread merged from somewhere else?
    HVACNUT Member Posts: 7,511
    Is it a 2 stage gas valve (3 wires) but wired for single stage only?
    Often stage 1 will go through an auxiliary limit in the blower compartment. If the limit is open, then obviously no fire even though there's 24 volts to the stage 2 terminal at the valve.
    It wasn't lawyers who programmed pre purge into the circuit board? It was smart people.
