Oil fill black steel and galv
Mainiac2000
Mainiac2000 Member Posts: 1
Hello, I am piping the fill and vent for heating oil with 1 1/2 inch black steel pipe. Is it okay to use galvanized elbows and couplers? I ask because I have them already and I would save money. If there is any reason at all not to mix the two aside from aesthetics, I’ll just go by the black pipe fittings. Thanks
    EdTheHeaterMan Member Posts: 12,506
    Should be fine
    EBEBRATT-Ed Member Posts: 20,482
    Depends on where you are located and if it will be inspected.
    I did that once piping a 275 gallon tank in Connecticut and I had a bunch of galvanized elbows to use up with black pipe.
    The inspector made me rip it out and change it.
    I still see nothing wrong with it.
    Some black paint would solve the problem.
