A2whp, solar thermal radiant cooling, circ 1993!
hot_rod
hot_rod Member Posts: 27,859
Dr Kilkis worked with Heatway back in the day. An engineer and professor from the Middle East Technical University in Turkey. Brilliant guy.
Designed some cutting edge systems, around heat pumps and solar powered water/ ammonia absorption heat pumps.
Kilkis served on many of the ASHRAE committee working on hydronic, radiant and snowmelt design standards.
After some metric conversions it will be interesting to see how todays ccA2whp compare.
