Upside down Runtal UHX radiator?
I have a silly question and rather than call up Runtal I thought of you guys.  Can you install a Runtal UHX-8-72 vertical radiator upside down?  If it’s on its own loop i assume it wouldn’t need a bleeder valve and the piping configuration on the runtal is in and out on the “bottom”. Piping is home run.
NH well driller and pump installer, 3rd generation
What one man can do, another can do.
    mattmia2 Member Posts: 17,483
    I bet if you contact them you can order it with the supply tappings at the top rather than the bottom.
    H2OBandit603
    hot_rod Member Posts: 27,859
    Bleed it at the end of the return pipe of the home run. A webstone purge ball valve for example
    I dont see how a bleeder would work ir be needed on a down feed panel rad?
    H2OBandit603
