Air Return in Basement
I have a 1500sq ranch style home with partially finished basement. I was watching a lot of videos and wondered if I should install a air return in the basement near the floor. I only currently have 1 air return on a wall in my hallway. Trying to understand if this would accomplish anything as far as basement comfort and removing humidity.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,553
    Adding a return to the room will improve the air circulation yes , I am not fond of a return in the cellar myself . For one reason the materials that I seen stored in them and the second loosing draft for combustible appliances , also in the cellar ....
  • damdolce
    damdolce Member Posts: 21
    Great thank you for that answer Big Ed! :)
    EdTheHeaterMan Member Posts: 12,581
    Is it a finished basement? will it be ducted from the finished room to the furnace.
    If it is not a finished basement, then I would advise against it.
  • damdolce
    Partially finished, have is and half isn't.
