Is this iron to copper transition OK? Main HW heating application.
Home owner near Minneapolis with cast iron radiators, one non working slant fin now ripped out, and hot water heat.
Mad Dog_2
  • eclecticmn
    eclecticmn Member Posts: 129
    What are the materials used for the reducer bushing and for the female sweat to MPT adapter? If this adapter is brass where can I get one? I can only find copper so far.
    EBEBRATT-Ed Member Posts: 20,467
    The bushing would be black either CI or steel is fine. The adapter can be wrought copper or brass does not matter. Probably copper is going to be what's available.
  • WMno57
    WMno57 Member Posts: 1,408
    No dissolved oxygen in the water in your hydronic space heating system. So mixed metals are OK. Mixing steel and copper can be a problem in domestic potable water systems (hot and cold), because there is dissolved oxygen in the water.
    Mad Dog_2SuperTech
  • Project42day
    Project42day Member Posts: 6
    Thanks. We just added a new boiler to our black steel piping and original radiators. We have the same question about mixing black steel and copper piping and possible risk of bimetallic corrosion. Do we need the contracter back to redo these pipe joints correctly? 1 image is recent joints x 4, black steel to copper in our new closed, hydronic heating system, 1 image shows earlier joins that included copper to brass bushing to black steel. Comments please
    Mad Dog_2
    EdTheHeaterMan Member Posts: 12,497
    edited October 2023
    Closed systems can use both ferrous and nonferrous components. Your photos look fine @Project42day .
    hot_rodSuperTechMikeAmann
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,671
    Looks good..the man wipes his joints!  Not a slob...Mad Dog 🐕
  • SuperTech
    SuperTech Member Posts: 2,669
    It's fine. No worries.
