Air Duct Cleaning
Should I ask the contractor to clean my air ducts before installing my new Furnace and Heat Pump?
  • bburd
    bburd Member Posts: 1,273
    edited September 2023
    Unless the system has been run for a considerable time without a filter or something else has seriously contaminated the ductwork, duct cleaning is not needed.
    Bburd
    HVACNUT Member Posts: 7,306
    Does the contractor offer duct cleaning?
    You would know better than anyone if it needs cleaning. Pop off a grill or check the air filter. Check the blower wheel for build-up. If it's 30 years or older, it couldn't hurt.
  • ChrisJ
    ChrisJ Member Posts: 17,148
    Personally,
    I don't allow anyone that does "Duct cleaning" on my property.
  • damdolce
    damdolce Member Posts: 21
    Thanks all for your comments, I appreciate you!
