SubDrive Magforce constant pressure
I had mentioned upgrading from standard pumping systems to constant pressure.  This system is doing 23 gpm at 70 psi with a basketball sized tank.
NH well driller and pump installer, 3rd generation
What one man can do, another can do.
    mattmia2 Posts: 18,503
    Is that well tank stainless?
    H2OBandit603
  • H2OBandit603
    H2OBandit603 Posts: 65
    edited September 2023
    Yes it is, a Flex Con FT-18S “Flow Thru” design with a little plastic insert that helps the tank turn over the water to prevent stagnation.  Works great for most of our constant pressure applications but we do use 202 or even 250 tanks on occasion on the higher gpm installs.  One of these days I’m going to wall mount a 202 H just to say I did.
