No date and time menu
I have a new NTI TRX 150C boiler. I have no date and time menu in settings. I am not using zone sensors to control the boiler, just a room TT and an outdoor sensor. The boiler works good otherwise. Is there a reason for this.
dko
  • HomerJSmith
    HomerJSmith Member Posts: 2,793
    Off hand without checking, those parameters may be in the installers programing, not accessible to the home owner. Phone NTI or check your install instructions.
  • Shane_2
    Shane_2 Member Posts: 200
    It will set automatically if connected to wi-fi. To set manual it is a combination of pressing + and - buttons together to set. Sorry don't remember the combo off the top of my head.
  • silleevets
    silleevets Member Posts: 3
    Thanks for the response. I have been through the installers settings checking the parameters and it is not there. It is supposed to be in menu settings after the INet setup but it is not there. I am using wifi. It is not a problem for me because I am not using NTI zone sensors. Thanks again.
  • silleevets
    Shane2 you made a comment about wifi keeping the time so I started thinking about it and checked the Itime setting in menu and it was on. I turned it off and now the hour minutes month day and year are in the menu settings after INet where it should be. It does not say this in the manual but I should have checked the Internet settings after I set up wifi. Thanks for getting me to think about it.
