AqaSmart 7600
KARLRR
Member Posts: 1
Display reads in Standby mode temperature 152 F. Pressing High Limit does change display. Cutting power cycles back to Standby mode display. Please advise supplies domestic hot water heat to Indirect Triangle Tube unit that prematurely leak under warranty the vendor will not honor.
Standby indicates no call for heat. The manual is here:
https://www.beckettcorp.com/wp-content/uploads/2022/05/AquaSmart-7600-Burner-Control-Manual.pdfBaltimore, MD, USA
Consulting0
