Religious Manifold
Will this get me into trouble?
PeteALarry WeingartenH2OBandit603
  • STEVEusaPA
    edited September 2023
    As long as you're not piping it on the Sabbath.
    I'd call it creatively ugly. I'm all for pipe bending, but it looks like this person came to the job with only pipes and valves, no fittings.
    CLamb
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,919
    Didn't it already? 🤪🙏 Nice low pressure drop menorah 👍
    Yours, Larry
    PC7060
    EBEBRATT-Ed Member Posts: 18,359
    Must be 1940s-50s. They did a lot of it during that time and during WWII fitting were in short supply.
  • kcopp
    kcopp Member Posts: 4,579
    Mazel tov
    hot_rod Member Posts: 25,457
    Amen!
     I like the creativity
    mattmia2 Member Posts: 13,807
    I thought it was 8 days, not 9, but i'm no expert.
  • Larry Weingarten
    Hi, That "Y" at the bottom is interesting too! Wonder if it's homemade? All quite clean. Took some skill! :)
    Yours, Larry
    Yours, Larry
    Looks like it was all done with that punch that makes a flange in the side of the tube that you can then braze another tube in to.
  • STEVEusaPA
    They still do it a lot in Europe, bending and T-Drill manifolds.
    Here's a recent one from our friends across the pond:
    PC7060mattmia2Alan (California Radiant) ForbesIntplm.
    Jamie Hall Member Posts: 26,257
    It really should be six side branches, which are lit in the evening (one on the first day, two on the second, etc.) and one central flame, which is kept lit. But -- there are other perfectly acceptable traditions and nine branches, rather than seven, is not uncommon.
  • Paul Pollets
    Paul Pollets Member Posts: 3,669
    Classic menorahs have 8 branches for the days of Hannukah and a 9th branch to hold the shammus, which is used to light the menorah candles. Nice work
    Different tradition -- depictions of the Temple menorah are seven. with the always lit centre. The nine branch one is more or less specific to Hannukah.
    It gets complicated. That's why you talk to a rabbi...
