Delavan nozzle ID ?
PHM
PHM Member Posts: 15
Do all Delavan nozzles include this and I've just never noticed?
What do the letters indicate about the nozzle? NOT the pattern letter - the other letters.
The nozzle in question is a Delavan 1.50 - 45ºA. Those two numbers are stamped into two of the hex flats - as usual. One and a half gallons of oil per hour at a one hundred psi pump pressure - with a forty five degree cone pattern being produced by the oil existing the nozzle. OK; got it.
But . . . on the flat between those two numbers - the letters: WDA are stamped in.
What does the WDA indicate ?
    Steamhead Member Posts: 18,710
    If I had to guess, I'd say it's a production code of some sort.
    Consulting
  • dko
    dko Member Posts: 669
    edited August 2023
  • STEVEusaPA
    For Delavan, WDA (hollow) or WDB (solid) are special nozzles for pressure atomizing (waste oil heaters) or humidifying (whatever that is).
    @PHM , was this nozzle installed in your burner? If so, what is the burner make and model?
    Consulting
  • SuperTech
    SuperTech Member Posts: 2,669
    The humidifying part is in reference to those awful plenum rotting mist humidifiers that were sold at one time.  They used a burner nozzle to spray water in the plenum of a furnace.  I only saw a couple of them in the wild. All of them had rotten plenums and rusted out heat exchangers.
    Yeah it will add humidity, at the expense of the furnace and plenum. Just another bad idea...
    STEVEusaPA
    EBEBRATT-Ed Member Posts: 20,481
    And the "A" after the 45 means hollow spray pattern
  • STEVEusaPA
    Never knew that. Thanks!
