Bosch Combi zone control wire to Uponor Smatrix Pulse controller board
cloudd
Member Posts: 49
I have a Bosch Singular 5200 and a Uponor Smatrix Pulse zone controller.
I became confused because relays are behind a NO 110V panel door. Is this a warning for people with 110V outputs trying to connect them? Or is it a warning I will fry a dry contact with 110v if I try to connect it? I do not want to guess. please help.
I only want to connect my Bosch combi Zone Control wires to the Smatrix controller which are dry contacts.
How do I wire them together? Which pair/terminal do I use to connect the Bosch combi to the Uponor Smatrix.
From my Bosch Singular 5200 Manual:
Here are pictures of the wires on the combi and the terminals on the Uponor Smatrix controller.
From the Uponor Smatrix Plus Manual:
Under the cover of the Uponor Smatrix Pulse Controller (Zone actuator / controller):
Here is the manual although this is the European version which is 230V I have the 110V. https://brandportal.uponor.com/m/802baa60a5b3ed2/original/IOM-Smatrix-Wave-PULSE-EN-1095344-v2-202006.pdf
Can anyone help?
Uponor support confirmed that the brown zone control wires on the Bosch combi should be connected to the boiler relay on the smatrix pulse controller.I didn’t want to to risk frying my controller. The no 110V confused me.0
