Jaga Clima 10 Trench Fancoils
Greetings!
I have installed several of these units, but am designing a couple larger projects and have some questions. Hoping someone here has a bit more experience.
Does TEKMAR or anyone else make a 0-10V controller for these units? I do know about the Messana controller. Any others?
I have several areas where 2-3 of these units will be ganged in the floor. I see that the company sells empty housings that can be combined to make the grill appear continuous, but it appears each unit still needs to have separate power, water supply/return, condensate connections. Is this true?
Your experience would be so helpful. Thanks!
    hot_rod Member Posts: 27,962
    edited July 2023
    Jaga has the controller built into the fan assemblies that clip onto many of their radiators It one that can be added
    Most of the electronic setpoint controls have  0-10 output. Ranco, Johnson Controls, Honeywell, etc. 24, 120 or 240v versions if you want to build your own cintrol
