Steam humidifier
cunninghamzach
Member Posts: 19
Can someone advise me on the what steam humidifier is the best for an hvac system?
We install and service the Aprilaire 800 series..
These units can be installed as a stand along with the fanpack or in a rigid duct with the injection pipe , if you are installing it in a duct it is highly recommended using a "Sail switch" to only allow the unit to work when there is air movement.
The higher end AA Thermostat/humidistats have a "Window schedule" and also base the humidification process on ODR which greatly reduces the possibility for overhumidification.
It also can be hooked up to your WLAN for remote access and notifications.
Hope this helps..1
- 128 Chimneys & Flues
