York 5 ton semi- hermetic compressors
Need 2-5 ton York semi- hermetic compressors rebuilt and/ or replaced in Michigan - anybody know anyone
  • GGross
    GGross Member Posts: 1,969
    Call local HVAC companies. Everybody is pretty busy doing A/C work right now so you may need to wait a little bit.
    HVACNUT Member Posts: 7,526
    You might have better results with 'Adapt a Curb' and call the boom truck.
    EBEBRATT-Ed Member Posts: 20,476
    If it is a semi hermetic it's probably used on refrigeration and not AC. There is a company in Canada that rebuilds them better than anyone in the states.
    1-800-567-2665 G & S Compressors
    They are the best. If they can't help you they can probably tell you who can.
