Zone Valve Control, No Line Voltage Available
One of my customers has an old Infloor system with an Infloor zone valve control at each manifold in an access panel in the wall. One of the relays is making a racket in the controller and I don't think the relay is replaceable. The control uses 24 volts to power itself and the zone valves, provided by a transformer in the boiler room.
Does anyone know of an off-the-shelf control as a replacement?
    mattmia2 Member Posts: 17,483
    it sounds like the world's most standard us zone valve setup, am i missing something here/
  • 8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
    Oh you mean because the transformer is remote? i think taco and caleffi have models of zone valve controllers that can use external 24vac. many models have the relays socketed so you might want to give the relay a tug and wiggle and see if it unplugs.
    Alan (California Radiant) Forbes Member Posts: 4,808
    edited June 2023
    I've never seen them.
    I tried and they did not budge.
    109A_5 Member Posts: 4,209
    edited June 2023
    Hello @Alan (California Radiant) Forbes,
    The relay is probably soldered to the circuit board. And probably not the problem anyway. Buzzing is just the symptom.
    Are all the zones used ? Can you switch to an un-used zone, may buy some time.
    Probably not much you can do to repair that unit unless you can change parts soldered on a circuit board. So change out the control, sell the old one 'Used, As Is' on eBay so someone else can repair it for not much $. Why send it to a landfill or other ?
    Probably a DC coil relay, I can't make out the part number on the side of the relay, looks like an Omron relay. The relay is probably not bad. The Capacitor(s) are probably fading (due to age) and one has faded too much. Relays and Capacitors are very inexpensive (the shipping may cost more), and easy to change with the correct tools and skills.
    BTW many 24 VAC zone controllers at https://www.supplyhouse.com
    One way, search for "zone control panel" then filter out all the rest by selecting the 24 VAC only units.
    hot_rod Member Posts: 27,859
    And you can recycle electronics instead of landfilling them. I suspect California makes that easy to do😏
  • Solid_Fuel_Man
    That was sly! Lol
