For radiant concrete overpour over rigid foam - fastening, seam-sealing, and vapor barrier
rossn
First off, want to say thanks to the great group of folks here... I have posted a couple questions related to my project, and have received some very professional and insightful guidance. What a great, positive forum!
Uninsulated slab, 4' below grade, which is getting a vapor barrier + 1-1/4" rigid foam insulation (25 or 40 psi EPS) + 1/2" pex + 1-1/4+" concrete pour.
Two questions:
1) Is it generally recommended to use a sheet vapor barrier, or a roll-on vapor barrier? Specific product recommendations are great... do want to be mindful of indoor air quality/product toxicity. Old slab, but can be high (up to 98%) humidity at times, but never any bulk water issues.
2) Do you loose-lay or fasten the foam in-place, and do you seam seal it? If so, what is your approach? Note: I do have some concerns about areas that might have a ridge, sloping area of slab, or uneven slab cut - where the foam may compress after the pour (esp @ 40 psi foam).
Two questions:
Well... tell me more
I wasn't aware there were spray foam applications on top of slab.... do they shave it flat, and what about what PSI is it?
I would want to also look closely at the environmental impact, as spray foams historically have had some pretty harsh blowing agents, though some are improving.0 -
This insulator seem knowledgable, not a sales pitch video.
There are a number of other You Tube videos about spray foam under slab. Check with local providers to see if they have experience with putting it down over subgrades.
I would guess the actual chemical make up of spray or board foam is similar? If it doesn't outgas in walls, probably no issue under slab. seems like a much better radon barrier with spray.
https://video.search.yahoo.com/yhs/search?fr=yhs-ima-st_mig&ei=UTF-8&hsimp=yhs-st_mig&hspart=ima&p=spray+foam+for+under+slab&type=q3000_A1BWP_set_bcrq#id=1&vid=621929fd5a08f0c4691ca906b21ea6e7&action=clickBob "hot rod" Rohr
Living the hydronic dream2 -
Ahh, very interesting. Sounds like a pretty cool option.
I think in my case, it won't be very practical, mainly because I'm trying to go for absolute thinnest assembly... as it is, I will have maybe 7'-9" ceiling clearance downstairs... IF I'm lucky. I guessing they'd have trouble keeping the foam thin enough to keep my full assembly between 2-1/2 to 2-3/4", but it would be great for Radon management, for sure.
As to the chemical makeup of spray vs board foam... foaming agents represent a tremendous source of warming agents in the atmosphere... I think I read recently somewhere between 5-10% of all greenhouse gasses, which is really major. The traditional blowing agents included HFC-134A, which if I understand the science correctly, traps 1430 times as much heat as carbon dioxide from your car. Basically, 1lb = 1430lbs of carbon dioxide from a car. A year or two back some of the mfg's came out with next generation blown XPS rigid foams, and at least one mfg brought theirs down into the (if I recall correctly) maybe 70-90x range. Now consider EPS foam insulation (ordinary styrofoam). It is rated at 7x (and fully recyclable). So, one really can make a difference in their choices and the downstream impact, just speaking from a scientific perspective is all.
This Chemical & Engineering News article goes into the transition away from HFC-134A. I haven't checked into the spray-on foams lately, but at least as of a few years ago, I believe they were using the same blowing agents, so I've tried to use blown foam insulation only in the most important areas.0 -
I believe they use much safer blowing agents now, check and see
I had them spray my shop walls at 1/2” thickness, then use fiberglass batts. I have seen a paper thin application applied also, for a air seal barrier. its all about adjusting the gun and the skill of the applicator.Bob "hot rod" Rohr
Living the hydronic dream0 -
That's good to hear, as I'm also going to be doing flash and fill upstairs. I'll check in on the spray foam.0
Thanks, I'll check with some foam guys. I see it more like I might be able to drop it 1/4" to add a little more ceiling height. For some reason, I was thinking that spray foam wasn't rated for slab contact, but my information is a few years old, so that may no longer be the case.0
About R 5 per inch for most foams. So 1/4" will not get much R value.
It will seal Radon, smells, air leaks, etc however.
There are a number of different foam formulas, I think it needs to be closed cell for ground or concrete contact. Maybe different psi ratings are available also. A good foam guy should be able to steer you.Bob "hot rod" Rohr
I believe @rossn was going to reduce the foam thickness by 1/4” from 1-1/4” to 1”; about r10 overall.hot_rod said:About R 5 per inch for most foams. So 1/4" will not get much R value. It will seal Radon, smells, air leaks, etc however. There are a number of different foam formulas, I think it needs to be closed cell for ground or concrete contact. Maybe different psi ratings are available also. A good foam guy should be able to steer you.0
