Control Modules
SugarRay900
Member Posts: 12
Are there control modules that accept two actuators without having to squeeze them in? I’m zoning my actuators to different thermostats. Right now my living room thermostat and basement thermostat each control two actuators. I plan to do this with my two bathrooms as well. So that one thermostat controls the temperature on both. I have a Uponor module and I have to pretty much squeeze the actuators into one terminal. Are there control module that easily accept two?
You could wire nut them together at the manifold and run one thermostat wire back to the zone control. You could also use smaller thermostat wire between the valve and the zone control unless it is a very long run so that 2 pieces of it would fit under the terminal.
Some pictures of exactly what you're using would help.0
- 87.8K THE MAIN WALL
- 131 Chimneys & Flues
