Small Water Leak from my Burnham Oil Furnace
MonkeyBoy_1966
my 20-year-old Burnham Oil Furnance has sprung a small water leak. Where the water circulates around the Blast Chamber, on the return side, a small leak popped up in January. My HVAC guys have seen this before in the same era Oil Furnaces. I can see where the leak is easy. So, now my F'ed up Harry Homeowner question.
Would heat-tolerant two-part epoxy work? It's a dribble at best and that is only when the furnace is running hard during the last couple of cold spells. It also supplies my domestic hot water. I was looking at JB Weld's "WaterWeld" epoxy, it is rated for 250° and J-B Weld 8297 HighHeat 500 Degree Epoxy is rated to 400°.
I have a really old house, 1770 and 1838, and the cellar was dirt when I bought the house. We poured concrete and install the system in an area that works well. I have a puddle about 2' or so around the leak and the water itself isn't a problem. My cellar is far from being air or watertight so I'm not overly concerned about that. We don't have mold and the water evaporates on days when the furnace isn't running a lot.
So, stupid idea?
So, stupid idea?
If you have a hole there, there are probably a dozen places ready cut loose.
You could give it a shot, but are you prepared for it cutting loose and draining the entire system into the basement.
I'd start on a replacement. Get a heat loss done, start pricing it up, before AC season is into full gear.
2 -
Add a boiler dope to the boiler to seal it to get you though....
As the Boys said, give it a shot but start putting away 💸 for replacement. Mad Dog0
- 135 Chimneys & Flues
- 16.2K Strictly Steam
