MAX Twin-Tier
SSmith
Member Posts: 14
Hellooo-
Anyone out there using the new MAX twintier RB441T for their slab radiant installs? At my former employer we used the older Max 395 model- it worked great. I'm in the market to purchase a tie tool. The newer model uses less wire but heavier gauge and is a small bit more expensive. It also ties the wire in a manner that leaves two cut tails pointing down at the tubing. I don't think it would be a problem but looking for some field input. Thanks!
-Sean
