Weil McLain CGI
AndrewHern
AndrewHern Member Posts: 8
hi everyone. I was looking into replacing my old cast iron boiler with a new one. I wanted to move the boiler and water heater to a different location in our basement. Therefore, we are going to be about 12 feet from our chimney or sidewall venting. That is why I was looking into the Weil McLain cgi boilers because their venting options are a bit more flexible. Any opinions on the cgi models? Any experience dealing with them? Are they loud?
I have also heard of the Weil McLain gv90+ series, but not sure about those. Any advice would be greatly greatly appreciated. Thank you guys.
also, should I use my new chosen boiler with an indirect water heater?
Andrew
  • Tom_133
    Tom_133 Member Posts: 988
    I installed my parents CGI in the apt house they own 18 years ago. It has needed one fan… That silly boiler just does work. I am also a fan of GV90+ boilers and the CG series. You need to decide on efficiency over repair bills and longevity if you are considering wall hung options. Thats my opinion.
    Tom
    Montpelier Vt
    AndrewHernknotgrumpy
    HVACNUT Member Posts: 7,526
    The CGi is a good boiler IMO. I'd go with it over the GV90+. Of the dozen or so GV's I've seen, none are piped correctly because nobody knows how to open a manual.
