Tankless Boiler Harmonics
Dyaeger
Member Posts: 4
I read a similar discussion but I have more information. In 2018 the Alaskan 7.0 earthquake hit and it murdered our boiler. We replaced it with a Bausch tankless boiler (gas.)The harmonic started when we got the new one. Another item: the exhaust vent wasn’t in code. A prior owner installed a second floor deck, and the pipe could not exhaust under the deck, so, they added about 10 feet. The sound builds up fairly quickly, stays loud wherein it can be heard both inside and outside, and loud enough that the neighbors can hear it. Then it slows down and stops.The harmonic isn’t constantly on. It’s definitely a thing with water source and it only happens when we turn the water on. A toilet will have this shorter harmonic and a shower will have a longer harmonic, maybe 15 - 20 seconds. It also doesn’t happen again if we use an overlapping water source, such as having a shower on and someone flushes the toilet. I thought it might have something to do with the 10 foot exhaust vent but my boiler has a sensor that if the right exhaust pressures doesn’t hit a certain #, it turns off. That problem was ice forming at the end up the pipe. I’d put a heat gun to end of the pipe, reset the unit, and it was fine. I solved that problem one summer by insulating the pipe so it’s stays hot enough for the condensation to empty the pipe before it freezes. None of the HVAC guys who services it can figure it out. Any ideas?
You have a tankless water heater or a combi boiler?
Natural gas or propane?
What elevation?
What model Bosch and what are the combustion numbers?0 -
Do you have a thermal expansion tank on domestic water ? You may have to recharge tank .
Is it a tankless or is it a boiler? Why is a toilet getting hot water? Was the combustion ever checked and/or adjusted?0
Thank you for the follow-up questions. The model # is T8700SE 199. It’s natural gas. It’s on city (domestic) water. Don’t know the combustion #’s but the tempeture is 140 (had to increase it from the standard 120 because we have a couple of scorch proof sink filters.) It gets maintenance every 6 months. No, the toilet isn’t getting hot water, but thanks for the chuckle.0
Oh, and the elevation of Eagle River, AK is around 950 feet.0
Is the gas pipe or exhaust corrugated? That could do it, especially on high fire.0
Does the installation manual discus checking and adjusting the combustion? Did the installer use a combustion analyzer to set it up?Bob "hot rod" Rohr
Living the hydronic dream0 -
I will check these questions and follow up. I appreciate your help so far.0
I had a Buderus GB-142 Wall Hung Mod Con do this. It was a bad air intake/gas valve issue less than 1 yr old. It was whistling. Loud. It was covered . Thats was the end of it mad dog0
You said that there are harmonics in the water heater when a toilet is flushed. If the toilet is not being fed hot water, the water heater will do nothing whatsoever when a toilet is flushed.
