Hydrostat to Taco relay wiring question
Good day all -
New oil burner with coil for hot water. Hydrostat one set of wires plugs into burner head, ok. Second wire (yellow & white) has tag "connect to circulator). First question. Do I run power from service disconnect to Hydrostat? Second question. Does the yellow/white get connected to the Taco, and which terminal? Is it going to the XX or TT on the Taco? I am confused. I also run power to the Taco from service connect as well? Thanks for the help!
  • Big Ed_4
    Big Ed_4 Member Posts: 3,530
    Taco what ?
  • Billob
    Billob Member Posts: 4
    Big Ed_4 said:
    Taco what ?
    Taco 2 zone switching relay
    HVACNUT Member Posts: 7,468
    If you have 2 heating zones, and a 2 zone relay panel, then neither. The C1,C2 wires (yellow and white) won't be used.
    You'll run 2 wires (14 awg) between ZR,ZC on the Hydrostat to ZR,ZC on the Zone panel. Since there's a tankless coil, turn the economy setting to off.
    BillobMikeAmann
  • Billob
    Thanks! DO I run power to BOTH as well? (The Hydrostat & Panel)
    Yes, power L1,L2 on both separately. You might need to remove a jumper between ZR,ZC in the Zone panel. I can't remember if there's one there.
    BillobSTEVEusaPA
  • Billob
    THANK YOU SO MUCH @HVACNUT!! Appreciate it!
    MikeAmann
  • Joe Mattiello
    Joe Mattiello Member Posts: 751
    Nice job with instructions.
    Yes, ZR is 120 volts out and ZC is 120 volts in hence jumper between the two.
    Joe Mattiello
    Taco Comfort Solutions
  • Rickoo
    Rickoo Member Posts: 54
    Joe, when the ZR/ZC jumper is removed, does it completely disconnect power to the relay box? If connected as above, is there even a need for a120v connection in the SR since it would be obtaining power from the aquastat?
