Hot Water Circulator Pump Rattling
D818
D818 Member Posts: 19
Hello,
The circulator pump for my hot water has been rattling pretty loudly for a few months now. I've read that this means it's on its way out but it still has been working ok. Is this ok or should I replace, clean, purge, or be concerned about a bigger issue?
Thanks,
D
    hot_rod Member Posts: 27,566
    How old is it?
  • HomerJSmith
    HomerJSmith Member Posts: 2,786
    It may be a swing check valve.
  • retiredguy
    retiredguy Member Posts: 1,095
    If it is a B&G it could be a pump coupler or worn out bearing assembly.
  • D818
    I'm not sure how old it is, we bought house a year ago. I replaced a taco circulator pump a few months ago. I'm thinking maybe I remove and try to inspect/clean. Not sure though, just want to make sure not a bigger issue or problem with pipes or pressure. Thanks all
    A pic of the pump and piping may shed some light. Most circ have date codes on them. In DHW applications, constant fresh water and minerals, they do wear out after years.
  • D818
    I tried to upload a video earlier but it wouldn't let me. This is a picture of room, the pump in question is furthest left labeled HW (next to one that says 1st floor).
    There is a small plastic check valve in that pump, Typically. It is often the cause of the noise.
    You would need to isolate that circulator and remove it to check its condition
    Air in the line could also cause noise. Possibly that green air purger is plugged/ scaled up. I’d remove the brass top and check that also.
    What pressure is on the system. 10-12 psi minimum.
    Some of the early check valve circulators would spit out the check. It would end up in the iso valve or piping and cause a commotion. Yours look to be about that vintage🤔
