Ultrasonic Flow meter
RayWohlfarth
RayWohlfarth Member Posts: 2,036
Has any tried using an ultrasonic flow detector to measure water flow through a hydronic pipe If so what do you use?
Ray Wohlfarth
Boiler Lessons
  • Brent H.
    Brent H. Member Posts: 173
    @RayWohlfarth
    There was a thread about this subject back in 2017 that might get you started:
    https://forum.heatinghelp.com/discussion/160915/ultrasonic-flow-meters
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,681
    No but I'd love to get one. Mad Dog
  • RayWohlfarth
    Thanks @Brent H. I will check it out
    @Mad Dog_2 I have always been intrigued by the technology since it first came out I remember the first ones couldn't do water and they were expensive
    Ray Wohlfarth
    Boiler Lessons
    109A_5 Member Posts: 4,209
    Hello @RayWohlfarth,
    Years ago I've seen them on the pipes in a Wastewater lift station. The paint on the pipes had to be removed to accommodate where the sensors were mounted. Seemed to work good when the pump(s) started up.
    EBEBRATT-Ed Member Posts: 20,486
    Ultrasonics.... Don't waste your money. Highly inaccurate. They don't work with glycol or if there are any bubbles in the pipe. Been there done that. Just inaccurate
    We had a job with a 250 ton chiller. Carrier start up guy showed low flow going through the chiller barrel by liquid filled gauges on the chiller. We did have low flow the "engineer" undersized the pump head. Had a balancer there with an ultrasonic said the flow was fine......it wasn't.
    We pulled the tags off the existing evaporator coils in the two AHUs and called the MFG. The PD through those coils was much more than what the "engineer" thought. We got it going by changing the pump impeller but it was still borderline low. Customer wouldn't pay for a larger pump (the right fix) so it stayed that way because engineers don't make mistakes and he got the pump he specified.
    hot_rod Member Posts: 27,859
    There are a lot of online rental places for portable flowmeters, if you want to try before you buy.
    After much research and opinions were just bought an Onicon for portable work.
    https://www.onicon.com/process/ultrasonic-flow-meters
    We will use it mainly for determining DHW loads for sizing and troubleshooting mixing valves. Also for hydronic troubleshooting. I suspect it will be as handy as a good thermal imaging camera for accurate date.
    Unfortunately ours will be in the Milwaukee office, so not much availability for me.
  • RayWohlfarth
    @109A_5 They intrigue me and I wondered how they worked
    @EBEBRATT-Ed Guess you answered my question. LOL Thanks
    @hot_rod Thanks I was thinking it would be helpful is diagnosing a trouble hydronic loop
    Ray Wohlfarth
    Boiler Lessons
    There are pros and cons to all the different types of flowmeters. We have a Badger brand at the lab in Milwaukee. I compared it to a certified turbine style, a BTU meter and the Quicksetter.
    On new copper pipe with a Discal air purger they were all within a few %.
    Air in the fluid does throw off the ultrasonic, and if the cuffs are not attached properly.
    https://www.rfwireless-world.com/Terminology/Advantages-and-Disadvantages-of-Ultrasonic-Water-Meter.html
  • RayWohlfarth
    @hot_rod Your wealth of knowledge amazes me. Thank you sir
    Ray Wohlfarth
    Boiler Lessons
