Navien NCB-190 cycling on/off
GeneBA
Member Posts: 17
My brand new NCB-190/080 is turning gas burner about every 5 minutes or so. I noticed the supply temp is exactly at 132F, burner stops when supply reaches about 160 F. By supply, I mean radiant heat, 2nd loop.
Zone valves and system pump for floor heating are connected to the boiler but the thermostats are physically turned off, not calling for heat and zone valves are positively closed.
I also hear wash cycle every 5 mins or so, immediately followed by zone valves clicking. The boiler is supplying 24VAC for a brief second. It shouldn’t be doing that.
Cycling only started after plumber connected floor heating. With just DHW on, I can’t recall the boiler waking up on timer or sensor all night long.
How do I turn this continious madness off? Is having an external Taco zone controller more reliable then using Navien’s built-in zone stuff or this is unrelated.
Thank you, Gene
Thank you, Gene
