Detroit Lubricator Company
New England SteamWorks
Member Posts: 1,529
Anyone have any info on these systems and pictured controls? The controls are on the returns. My only guess is some kind of electronic trap, but I've never heard of such a thing. These are installed on a 1-pipe system, except for the indirect convectors, which have returns and these controls.
newenglandsteamworks.com
Looks like aquastats on the supply and solenoids on the small pipes. What are the small brass pipes?
If the indirects had a fan in them, the switches kept the fan from blowing cold air? Or some way to zone or control the indirects from overheating?
Never saw anything like it.0 -
I think this might be the patent filing.
"My invention relates to electric. switches, and more particularly to a switch which is automatically operable by temperature responsive means or the like.
An object of my invention is to provide an electric switch which is particularly adapted to be secured in heat conducting relation to a fluid conveying conduit or the like so that the automatic means for actuating the switch will respond to the temperature of the fluid in the conduit."0 -
When I started in the HVAC business in 1968, the only experience was with their modulating gas valves. I only saw a few of these since they were on atmospheric boilers of the very wealthy. Back then, replacements valves could be purchased from The Sid Harvey Company. Anytime these valves needed replaced we switched to on/off valves since the modulating valves needed a lot of TLC.1
How would a steam trap work here? Maybe it has something to do with opening the return once the radiator is filled with steam so the vent doesn't close from the return.
I wonder if it has something to do with sensing when the piping is filled with steam to control the boiler although it would have been coal at the time these were installed.0 -
I was thinking it senses steam temp and closes, keeping steam out of the returns...New England SteamWorks
newenglandsteamworks.com0 -
If it is 1 pipe, steam in the returns isn't a problem except for these which are set up 2 pipe, right?
So I am thinking that valve is normally closed, it isolates the radiator return from the main return, the radiator gets steam from the boiler, it vents through the vent next to the aquastat, once the radiator is filled with steam it trips the aquastat and that opens the valve connecting the return to the rest of the system. My guess is that is keeps the steam in the main return from closing the vent for the radiator early, but I will defer to your vast experience.0 -
Steam in the returns going the wrong way can be a problem....New England SteamWorks
Is there any evidence of wall tstats in the rooms?
Could they control air venting as TRV's do for 1 pipe steam vents?0 -
I think you're right. @New England SteamWorks , do (or did) these indirects have fans?Long Beach Ed said:Looks like aquastats on the supply and solenoids on the small pipes. What are the small brass pipes?
Never saw anything like it.Baltimore, MD, USA
Consulting1 -
Thank you as always Gentleman! I was not on that job, so with this new information we can return and solve the mystery!New England SteamWorks
newenglandsteamworks.com1
- 128 Chimneys & Flues
