Is there an online calculator taking btus load, pipe size and length...
Is there such a thing as an online calculator where you can plug in your btus load, pipe size and length, and have it give you pump recommendations or at least head and flow?
Thanks!
    EdTheHeaterMan Member Posts: 12,508
    edited February 2023
    Are you looking for a commercial application? OR are you looking at residential system (less than 300,000 BTUh)? For the small stuff, a simple rule of thumb is found here: https://documentlibrary.xylemappliedwater.com/wp-content/blogs.dir/22/files/2020/01/FH-Z100B-BG-Zoning-Made-Easy-2.pdf starting on Page 5 and ending with this
    But I may have used a slide rule in the past. Now there's an app for that.
    EBEBRATT-Ed Member Posts: 20,486
    @watercourse
    The best way is to use the old Bell and Gossett wheel that Gill Carlson invented. You can get one from your local B & G rep. If you want the electronic version, you can use the B & G "system sizer" which you can download for free from B & G (zylem) web site.
    Like any calculator the more accurate the #s you put in the more accurate your answer will be.
    Once you have the pump head and flow calculated you can call your pump supplier and they will size the pump.
    hot_rod Member Posts: 27,859
    Turn your btu loads into gpm required as @EBEBRATT-Ed suggested.
    Then find pipe sizing tables online. The Plastic Pipe Institute has a great one for any plastic pipe material.
    Copper or steel pipe at engineeringtoolbox.com
