Main vent placement
Is it ok to put them on these horizontal sections of main and return? They do go on about 20' further but from here on they run up against the floor where there's no room to go up.
Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
You can drill and tap for 1/4" which will handle a Gorton #2.
These may be over kill with the strainers and pipe supports.
It was an old abandoned/abused system.
Great idea. Although I wanted to give each a shut off valve as well. Is it ok to go without the valve?
Awesome. Will make the job some much quicker and easier.JUGHNE said:The 2nd picture added is a better shot. Valve would not be necessary. Just shut the system down if needed, plug or cap if you have a leaker. Seldom with G2's.
* Ended up being a 5 minute job, so relieved, my pipes will be too!
Best piping practice would tap into the top of the pipe or at 45 degrees from the top, minimizing condensate intrusion. Black pipe with iron elbows are preferred. Galvanized fittings can flake and clog vents.
Nice work to a great system!0 -
So, how much better does it heat?
Consulting0 -
Thank you, the pipes are black.. will swap out the elbow and adapter for black as well and get a 45° on there coming out of the main. Thanks so muchLong Beach Ed said:Best piping practice would tap into the top of the pipe or at 45 degrees from the top, minimizing condensate intrusion. Black pipe with iron elbows are preferred. Galvanized fittings can flake and clog vents. Nice work to a great system!Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
@Steamhead everything on that side of the apartments heated up much quicker, so far so good
1 -
Excellent. We'll be interested to see how much gas you save.
Consulting0 -
The bill for last month just arrived and is brutal. Looking forward to something smaller next month.Steamhead said:Excellent. We'll be interested to see how much gas you save.
Sitting by the boiler right now. It just cycled at 0 psi with the thermostat shutting it off. The thermostat is located in the living area above the newly-added vents. Pretty happyBryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
- 128 Chimneys & Flues
