Hydronic valves
Can anyone tell me about the valve  lower part of the picture it has an H on it.  Hydronic heating loop
  • JUGHNE
    JUGHNE Member Posts: 11,634
    The lower left device looks like a quarter turn plug valve for balancing flow.
    Loosen the nut and rotate the slotted plug with a screwdriver.
    Slot parallel with pipe is open....perpendicular is closed.
    Usually not 100% shut off but close.
    Top left may be for bleeding air?...1/4 turn also.
    EBEBRATT-Ed
    hot_rod Member Posts: 28,248
    The top valve also look like a gauge cock. If it is bushed down to 1/4” it may have been used to check pressure
    Or a manual vent port
