Radiator supply valve making continuous noise
Hi - hope this is an appropriate place to post this. I'm currently living in an apartment with steam radiator heating. Lately on the main living room radiator there has been a loud hissing noise coming from the open/close valve area as well as a pipe in the room adjacent that sticks out from the floor (not sure if this is related to radiator, but I believe so?). The noise happens both when the radiator is on and off.
The noise seems to occur sporadically. It happened a few weeks ago and then stopped for a decent amount of time and now it is back. Any ideas on the cause and potential solutions? Maintenance is an option, but I would prefer to solve myself if it's an easy fix. Thanks.
    EBEBRATT-Ed Posts: 21,178
    Hard to say maybe a few pictures could be posted. Could be a bad valve with internal problems. Could be a steam leak from the valve packing. Use a mirror to look for steam leaks ....it will fog up when the steam hits it.
