My one bedroom upstairs has no heat
sirman
sirman Member Posts: 1
I have gas heat which is baseboards everything was working fine and then when I turned on my heat I realize the second bedroom upstairs has absolutely no heat
    EBEBRATT-Ed Member Posts: 20,481
    Check the water pressure gauge on the boiler. Normally 12-15 psi cold. Try bleeding the radiators. Add water as needed to maintain 15psi
