Tekmar Radiant Thermostat Replacement
CFS
Member Posts: 2
Hello everyone. I've been having radiant floor heat issues in the bathroom and my plumber said its the thermostat but of course he did not com3 back to replace it. All in all i ordered the Tekmar replacement since my old one is discontinued
Old thermo - tekmar 508
New thermo - tekmar 518
I think i matched up the wiring correctly but wanted to make confirm before i blow my system:
508 numbers 1 2 3 4 5 6
518 match S1 = 1 COM = 2 C = 3 R = 4 Rh = 5 W1 = 6
Thanks in advance to everyone that responds
Thanks so much Ed! I had it exactly as you stated which is a relief! I also hate the extra terminal but figured the no power terminals aren't going to damage anything if I had them reversed! Thanks again! Cheers!0
- 125 Chimneys & Flues
