Condensate neutralizer -
gyrfalcon
gyrfalcon Member Posts: 189
Hi all,  I was in the boiler room at my work yesterday and noticed that the boiler condensation drain was dripping water as it should but…. I do not see a condensate neutralizer , there appears to be a y pipe/ trap apparatus at the bottom of boiler and drain attaches to it.  Boiler and building are from 2008/2009.  Do we need to be concerned at this point?
Slant Fin Galaxy GG100(1986) , 2 zone hot water baseboard, T87 Honeywell thermostats.
  • gyrfalcon
  • HomerJSmith
    HomerJSmith Member Posts: 2,794
    I'm more concerned about the cabinet being eaten away with acidic condensate. Not having a condensate neutralizer is a concern for the sewage sys.
    mattmia2kcopp
  • gyrfalcon
    @HomerJSmith, yes! That too!!  I’ve pointed that out to management
    mattmia2 Member Posts: 17,451
    Depends on what type of drain it is going to. If it is all pvc then it is ok, if it is cast iron it needs a neutralizer.
  • gyrfalcon
    Looks like pvc.  I’m not sure what it connects to beyond the building
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    Hopefully not on a septic without a neutralizer...We have seen leach fields that were only a couple years old that needed to be redone due to the acidic propeties killing the Nitrobacters causing the laterals to become clooged.
    mattmia2kcoppgmcinneshot_rod
    hot_rod Member Posts: 27,815
    While it is probably diluted by the time it hits the public sewer, manholes and the base are concrete, the condensate really attacks concrete
  • gyrfalcon
    Thank you all for the insight
  • HomerJSmith
    The house may be PVC or ABS plumbing but the lateral to the street may be cast or Transite Portland and asbestos cement. Transite needs a neutralizer.
