Zone Control Wiring
Member Posts: 4,836
Everyone has their own way of wiring, even on a controller where they provide you a terminal for every wire. This installer sent 24 volts (both "R" and "C", large red and blue wires) directly from the transformer to the thermostats and then a return wire from the thermostat to the "W" terminal.
Was there a picture to go with this?
Otherwise, It sounds like R toEveryone has their own way of wiring, even on a controller where they provide you a terminal for every wire. This installer sent 24 volts (both "R" and "C", large red and blue wires) directly from the transformer to the thermostats and then a return wire from the thermostat to the "W" terminal.
R w to W and C to C is what you would expect.
Makes more sense with the photo.
Someone thought they can wire a nest
Looks like an additional relay involved also
Does it work?Bob "hot rod" Rohr
Living the hydronic dream0 -
Maybe but why .... It would be simpler to rip the board out and hard wire
Looks like they just basically mimicked what it looked like when it was wired without the zone control.
Not a relay. It's just a toggle switch for those who prefer toggles to unplugging a cord.hot_rod said:Looks like an additional relay involved also
Does it work?
This was installed by a company in California, early on in hydronics who were very good at marketing. They used large water heaters for DHW and radiant (via a HX), homemade expansion tanks, non-barrier tubing, non-ferrous pumps, no remote manifolds (all home runs to the mechanical room)..........8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Are you sure they didnt burn out some part of it0
Has this ever worked before the Nest Thermostats were installed? I think they used the correct T terminal for the W. And R is R where ever you pick it up from. Same for C... C is still C where ever you pick it up from.
Looks like there is custom wiring in order to confuse their competitors. Kind of a guarantee that the customer comes back to the original installer for service. "If the competition can't figure it out, then I guess we need to call the guys that installed it"
Sounds like Weil McLain parts. Can't use lower price generic off the shelf parts, Must use the Weil McLain part number or it won't work.Edward Young Retired
There are no Nest or other wi-fi thermostats; simple setback ones that are not power stealing. Some installers like to power thermostats with a "C" wire so you don't have to change the batteries so often.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab1 -
- 129 Chimneys & Flues
- 122 Geothermal
