Auto mag zone seems to be stuck shut
snowshoe22
Member Posts: 2
Is it possible that the coil is bad or that the plunger is just stuck? What is this likely to be? You’re dealing with a pretty handy guy but I have zero experience with boilers. We moved to a new house.
Replace the zone valve with a new one and it will give you years of use0
Some of those are power close, do you know which model you haveBob "hot rod" Rohr
Living the hydronic dream0
- 125 Chimneys & Flues
- 19 Recall Announcements
