Why no stainless steel screws for valve washers?
CLamb
CLamb Member Posts: 348
It seems that every time I replace a washer in a valve I find the brass screw holding it in place has pretty much rotted away. Wouldn't stainless steel screws be more durable?
MikeAmann
  • JUGHNE
    JUGHNE Member Posts: 11,591
    How old are the valves?
    SS was very expensive compared to brass, 20-30 years ago.
    hot_rod Member Posts: 27,703
    must be some aggressive water?
    Stainless seems to be more common now. I bought repair parts from PM.
    There stainless screws bib screws had a a dab of thread locker on them also.
  • CLamb
    It varies from 5 or so years to about 70 years.
    newer chemicals use in water treatment can cause the older brass to dezinicify. All new brass is DNZ dezinicfied
    CLamb
    Yeah, I don’t have it spelled correctly and spell check doesn’t pick it up.
     Always good to have Z and x words ready for Scrabble
    Alan (California Radiant) Forbes Member Posts: 4,767
    edited December 2022
    I've always used monel (nickel + copper) bib screws. This is an old Sexauer kit that I've had on my truck for 40 years.
    CLamb
  • CLamb
    Thanks! I will now buy some monel screws.
